New Build using Psychohubs, 10s Sensored FOC (video added)
Deck: H5 from socalskateshop.com http://socalskateshop.com/index.php?l=product_detail&p=69593 Trucks: Surfrodz TKP With 10mm Axles https://www.surf-rodz.com/products/trucks/tkp-full-color-kit Wheels: PsychoHubs with Matco Tires http://psychotiller.com/product/6-billet-wheel-hubs Enclosure: Custom version of Psychotiller’s Monolith Lo Pro http://psychotiller.com/product/25-monolith-low-pro Motor Mounts: Psychotiller TKP Mounts Custom 10S4P Battery Made From LG HE2‘s ESC’s: TorqueBoards VESC’s diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/ Self Soldered Vedder 1.3 SparkSwitch Pulleys, Belts: Vextronics 60T and 16T Psychotiller 12mm Motor Pulley, 345mm 9mm Belts Motors: TorqueBoards Sensored 190KV 6355 Power Meter: https://www.amazon.com/gp/product/B01LQ7MT4K/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Haven’t hit top speed yet but in theory this should hit 27MPH. These PsychoHubs are really balanced at high speeds even with the trucks fairly loose. The tires handle pretty well in the dirt. I have plenty of clearance and I can interchange the wheels with 97mm flywheel clones. I’ll try to get a video as soon as I can.
https://www.youtube.com/watch?v=Lho7Ywl5rMQ&feature=youtu.be
Really Nice build!
Do you have a close up pics of the drive train? I’m working on a very similar setup Did you have to put 10mm bearings in the psychohubs? Also how did you fill in the drop through holes? I assume you got the 177mm axel trucks. What’s the total length of widest part of the axel tip to tip? Sorry for all the questions
Awesome @mccloed! Do you use all of the space in the custom enclosure to fit the battery, VESC, and (I assume) a BMS? Also, why did you select TKP vs RKP?
Looks great! You’re running FOC? How many miles have you put on it so far? I’m thinking about doing a build with pneumatic wheels as well.
No biggie. Ask away!
Yup. Pretty much used most of the space. This board is only 38" long. I chose the TKP’s because they carve a little better than reverse king pin trucks. This is especially good for off road, in my opinion.
Yup. Using FOC. I’ve only put about 10 miles on it, so far. But the first three were pretty hard miles on dirt and grass to test the strength of this set up.
Does that mean that the total truck width is even narrower than a standard caliber 2 (180mm) ? Do you have any issues with wheel bite?
This is the setup “street” version I want to build/ride.
beautiful.
Wicked wheels! What type of terrain are you expecting to ride on with that? That would be perfect here in the desert!
No wheel bite. I added 30mm to each side. So, total hanger length of 237mm.
For @Bender:
@nmagz3, I plan on using it on packed dirt and grass. Worked great last week in AZ on the side of the road. Went into some small rocks and it went one way and I went the other.:smile:
Thanks @mccloed How do you add 30mm to each side? Is that with a product from Surfrodz?
Thanks so much for posting those pics!
Do you have some sort of spacers between the wheel pulley mad the hub? And did you have to drill out the hubs to fit 10mm bearings or are the outside diameter the same as standard 8mm skate bearings?
Also thanks for all the links in your first post it really makes it easy to research gear.
Hey @Bender, they are 3/4" standoffs and an extra bolt to space the pulley out a little. The bearings are specific 10mm bearings and are the same diameter as 8mm bearings. These came with the surfrodz.
Are you sure there are enough screws holding that enclosure on? :joy:
You have to add 30mm spacers to each side and get 80mm long hardware. The longest surfrodz come with is 70mm.
Nope. I need to add 50 more like this guy I know. :unamused:
As long as you order the 177mm hangers with 10mm axles you’re good. Because you’ll end up getting longer axles and 30mm spacers elsewhere anyways.
