If they are identical one thread if they are diffrent two
They will be different.
Do two diffrent threads then
I got 12mm belts from https://www.vbeltsupplies.com/products/vb-265-5m-12-timing-belt-synchronous?variant=8937225925 ($4.56 + shipping).
Ok cool. Matter fact a box just came in today. Man iâm excited . Lol
Add VbeltSupply, cheap and good quality
The Tacon Big Foot 100 295 kv motors should be added. Theyâre great for a dual 6s eboard. Also, having links to everything would be convenient.
EDIT: Iâve gone ahead and added it myself.
Bump bump
what about Ollin Motors, MBS-All-Terrain-Wheels and 3d-printed-pulleys from thingniverse?
Little off topic but, seems like Maytech has some of their own on here.
This needs a lot of updating
agreed. I will try to find some times this weekend to update it some. Mods can update it also.
Can I use turnigy 3s 5000mah batteries if I canât get anything else?
What must I do if I already have trucks(bear trucks) and I donât want to buy new trucks, what motor mount must I use?
I donât know any motor mounts that work for bear trucks. Caliber IIs arenât too expensive.
Iâm already like $150 dollars over my budget thought, so should I just buy the enertion single mount and file the bear trucks to fit it?
I think the caliber hanger is probably bigger than bear so you might not be able to file it and make it biggerâŚ
Zealous bearings should be added to the list, they have an integrated spaced and are lubed with a white lithium-like oil that does a great job of keeping out water. And cheap AF.
Hi, I would like to submit some parts from my UK store which recently opened - www.Proto-Boards.com Motor Mounts- ProtoBoards Motor Mount Drive Hub- ProtoBoards 9mm 36t Drive Hub ProtoBoards 12mm 36t Drive Hub Wheels- ProtoBoards 83mm, 90mm, 97mm Wheels (flywheel clones) Controllers- ProtoBoards Thumb Stick Controller Thanks!
If you donât like Velcro, and I donât, this is the best stuff in the world for mounting electtronics.
https://www.amazon.com/3M-03614-Scotch-Mount-Molding-Tape/dp/B002JOVUO0
Itâs actually cheaper at OâReilys than Amazon, just bought some for $7.22.
