New Circular Truck Motor Mount $40 SHIPPED - PICTURES!
You can change the units in Document Settings:
Yea, it was opening in mm just looked like the size of inches or cm
I’ll try that again tomorrow tho
I just tried it again and it opened in inches, now I feel like an idiot :joy:
Even when you already opened the part you can change the units in Document settings. Does that not work?
Nope it works, was just being an idiot earlier
This is kinda what I meant with the teeth. Reason being is that on a completely round truck, it gives it the chance to dig in to the meat of the truck to keep it’s position, whereas a perfectly rounded surface will inevitably slip at some point…
Still having the same problem as yesterday…
Any ideas?
Is it an STL file? I do have some problems with STL being way too large. Send you a 36T pulley I’ve sketched up.
Yup, I’ve had problems like this before with stls too…
I’ll try the file you sent me in a bit :grinning:
Will it fit Evolve truck hanger (attaching plate) ?
Nope. Those trucks are square.
Do you know if there is any other that could do it?
Not that I know of
This clamp design is weak in its ability to hold onto a circular part. The teeth have little contact surface area that a clamp type design is not adequate.
Ok man, thanks.
I think that his design would work just fine since the teeth would dig into the clamp, keeping it from rotating
Good luck!
hopefully one of the last renders before milling starts, ive got one buyer right now, guess paris trucks are a thing of the past :pensive:
I like them better than calibers :blush:
