That makes 2
Oh also: forgot to say, I redesigned the mounting plate to have scrape guards for the motor so if you hit a massive curb it wonât destroy your motor. And it looks better in my opinion
Thereâs the final design!
Wasnât able to mill anything today but now Iâve got 3 days to try to figure out fusion CAM
Would anyone be interested in a mount if it came with an adjustable idler? Kinda like @Lionkev55âs mounts
It would only cost about $5 more per mount for an idler
Assembled without a belt. Thatâs an APS 6384 (thanks @anon42702729). If everything goes well I will be able to mill a few this week on the manual mill
Iâve changed the shape of the arm a bit just to make milling faster and easier since I have moved to a manual mill since the school with a manual mill has the right mills to cut aluminum so I donât have to wait for the carbide mills to come in. Iâll update later today when I have a definite time
Whatâs happening with this?
If your talking about milling: The teacher that would let me in to use the manual mill hasnât been at school the past couple daysâŚ
I reaaaalllly want one or two of these done
Youâre going to try and manually mill this?
Well⌠yes. I have optimized the design for a manual mill (took out tiny corners, added straight lines). The holes will be done with a drill press.
Will be a hell-uv-a job⌠good luck
Yea it sure will be
If it goes well and the prototypes work I will send the files to a local machine shop and get them to do a couple (probably about 5 for Paris and 10-15 for caliber)
Hey man, can I offer a suggestion? I know you are strapped for cash, but I would recommend holding off accepting orders until you have the mount machined and tested. Once you get it milled, you probably will need to make some revisions. Speaking from personal experience, it took me two iterations of both the mount and clamp to come up with a solid design that didnât slip. Something that works perfectly on the bench and feels completely secure might fail in two blocks (like mine did)
It doesnât seem like you are very close to having a final product. You mentioned using a local machine shop, but I think you may have a hard time getting them professionally machined while still meeting your $40 shipped price. Have you gotten quotes yet? Machinists are more expensive than you might think
Do you happen to have access to a waterjet? It would be a cheaper alternative to CNC milling
You can do the holes on the mill too
haha yea havenât taken a dime from anyone yet. I think the clamps will actually be done on a lathe. Little do you know this is Clamp MK19 and Arm MK27
Milling can be done quickly and easily since I have access to tons of things (lathes, cnc, manual mill, laser cutter, 3d printers). Machine shop was only mentioned in the case that I get like 50 orders or something crazy.
I also know holes can be done with the mill but it would be crazy hard to get a perfect circle using a manual millâŚ
Alright peeps. We are making progress, slowly but surely. I have decided to use the schools lathe for making clamps, should be much easier than a drill press and can be accomplished in 2 cuts.
thinking of using that to cut the outer diameter and a run-of-the-mill (pun intended) 18mm drill bit for the inner clamp part that fits over the truck. The other three holes will still be done with drill press but they should be super easy
I would put a idler on it then it was be the beeâs nuts
Add an idler and youd be flooding with money lol
will do
be on the lookout
added an idler to the design. since it is last minute the idler will be optional. if you would like, I can supply a mount with an idler, ready to roll for an added cost.
milling should begin on monday. might take a bit to get a fully functioning mount.
Would these compatible with racerstar 5065.
