Hello eSk8 builders! I’m Borja Diaz, skater, longboarder, snowboarder and digital fabrication addict I’m new in the electric skateboards world but I have researched tons and tons of information and finally I have all my components and instructions to start building my own electric board. I have met 1 industrial engineer and 1 programmer and we are going to investigate together new methods, techniques and implementations to this kind of vehicle.
Implementations:
-“On board incrusted batteries covered with carbon fiber” to have the slimmest board possible
This image is from the work of @lowGuido-Tracking status of the board (battery, heat, velocity…etc.) by websocket encrusted in a apk (I dont know about programming but my buildmate said me something more or less similiar to this) -Automatic Following system for that moments when you use the board to carry things or you are busy to carry it by hand, that way the board follows you wherever you go (This things will be included in the future, first we are going to make a “regular” electric board while we investigate on that)
Specs/Components:
-6S2P (12 cells: 3,7v 1s 5000mah 20c each one) -236kv SK3 motor -80A SBEC -GT2B Controller -6s 10a BMS -Orangatang Kegel 80mm 83a wheels -12 teeth pinion and 36 teeth spur (2,57 reduction ratio) -HTD 5mm 15 timing belt -24v 10a power supply
Aproximately 31Km/h speed in a range of 15km
That’s all friends See you in the comments
