my focbox are coming any day now!!! so excited, just need a new soldeing iron… i am really looking forward to a safe ride now that im almost healed up… yeaaa progress!!
But you dont have the PCB design files. Or do you? :3
I dont, but I will try to get them from here. I have the layout, the basic connections and an open source license so I dont see why it couldnt be possible, a little of work required tho
Obviusly it would still be nice if the source releases the schematics as the license invites them to share the files
I have Euro group buys happening for any interested parties. I am about to open a second GB.
Just received my FOC…Im using 3 wire twist throttle… So…can I still connect bluetooth etc…
thnx
I have just ordered 2 FOCBOX and plan to run them in FOC on my MTB build. I can mount them in the battery enclosure or near the motors. Which is better?? Longer battery cables or longer phase wires?
JUST GOT MY FOCBOX’s HOT DAMN they look sweeettt!!!
I have found the schematics for the width of the FOCBOX but cannot find the height. Anyone know?
This may be too late, perhaps you have your answer already. Also I’m no expert so will humbly accept correction, but:
- Long battery wires can be bad as more inductance leads to more back emf and those spikes can shorten the life of the ESC. That’s why there are big capacitors in parallel to the inputs from the battery and you can compensate for long battery wires by adding some more. There is a ton of advice out there, (low serial resistance, close to the ESC as poss etc.), but you can just buy little boards with appropriate caps on them, boards with natty holes and tabs such that you can get them really close to the ESC.
- Long motor cables (phase wires) are less of an issue and tend to just introduce more loss. There is a limit of course, you don’t want massively long cables, but actually inductance on those ones is apparently slightly helpful. You may get less mileage as wasted energy heating the longer cables but performance and durability shouldn’t suffer too much. Those are generalizations, quite possibly wrong (really) and everything has it’s limits. But I would err on shorter battery cables if you are forced to make a decision, and if the battery leads are still over 10cm then bolstering the source capacitance might be a good idea anyway especially with the giant currents an MTB is likely to draw. Caps are usually a lot cheaper and easier to get than new ESCs, (especially swanky VESCs) and having it break when out and about would suck.
Swapping the wires does technically void your warranty, as any modifications to our product will. Don’t worry though - you can always purchase the platinum warranty on the FOCBOX which covers user modifcations too!
Just FYI Adrian, your focbox has had the wrong labeling for the sensor wires since the vesc-x. Including the new batch.
Thanks for letting us know Jinra - we’ve just been made aware of this issue too. I’ll try to get something posted today so we can clarify the issue (unless one of you awesome, knowledgeable community members beats us to the punch, of course).
Yep, your +5v and GND wires are correct, but your temp wire label is in the wrong place.
The highlighted label “T” should be next to “5V” and H1, H2 H3, should be next to GND.
Damn, that’s inconvenient! Thanks so much for dropping some knowledge for us to help out our customers. We’ll update the FOCBOX Help Guide using this info.
How’s the FOCBOX working for you otherwise?
No idea! They’ll be going on my hub build whenever I get around to buying those. I will say the FOCBOX build quality is very nice with the matte plastic enclosure and metal heatsink.
FOCBOX is working spiffy, just went for a nice run… quiet as a church =)
I just hope your not referring to a gospel church
I have a distance of about 16" between between my batteries and my FOCBOX. I want to run FOC, which wires should be the longest?
Awesome trancejunkie! Glad to hear it’s working well!
