I got contacted by Maytech about a new Dual motor ESC that they are beginning to sell. Here is the pictures and and specs
I can get them for you for 92 dollars ESC.
Detect and work with most motors in the market (Sensorless/Sensored Motor)
Dual Drive speed controller, can work with 2 motors
Voltage: 6-10S Lipo
Cont. Current: 30A
Burst current(10s): 50A
Protection function: Signal loss, Over-heat, Low-voltage, over-current protection
Dimension (LWH): 74.55020.5mm
Weight: 98g
I am new to building electric skateboards.
T he cont. Current - if i have two hub motors, that each have a max current of 22A. So would these be ok with this esc?
And for the 92$, you can connect 2 motors into it?
it’s 30a x 2 with a claimed burst of 240a x 2 . the burst seems a bit high but the Max Continuous discharge of 30x2 = 60a should be fine for you’re hubs. Are you running the Maytech 800w 90mm hub motors? if so, these were pretty much made for those and should work perfect
Oh cool. Yes i do have the 90 mm maytech hubs. I’m glad there are such helpful people out there. And as i understood i only have to buy 1 of this to connect 2 motors into it right?
Yes I am also a dealer and stock these. They are great for dual budget build good quality buy no match for the VESC running dual. Look the wires of the cheap eBay all in one units. Also running on 12s20171231_214635|666x500
