this will be my first attempt to build a board. i am using the elos board which is surprisingly agile. its only 17.5 inches long. this board will be used to commute around manhattan and is solely being designed for the fun of a portable ride. as i want to keep the board light, i’ve opted to go with samsung 50E 21700 cells. at 5 amps a pop, they harbor a little more umph than the 30q’s ive played with in modding my boosted board.
i will pair this to a buildkitboards 6354 motor with the 15T /36 pulley from BKB.
ollin popoca 90mm wheels with risers as to avoid wheelbite (no face on the concrete, please!)
i have a focbox vesc
boardnamics mounts
riptide risers if i need to make my wiring a little more covert.
thinking about a tiny discharge only BMS
will probably KYDEX my own enclosure when all is said and done.
my question - can i do this with a 12s1p setup? i do not need extensive range and am trying to keep this relatively light. will i encounter tremendous sag? i’m not trying to go more than 15 mph on this thing. hoping for 6 miles or so of super portability. looking forward to advice/feedback!
The 50E only have 15 amps discharge? That’s seems a little low. If it where me I’d sacrifice some watt hours for more discharge because it’ll mean less sag.
For a 1P setup I would get the Samsung 30T or 40T, the 50E is too low power, unless you are gearing for a low top speed and don’t plan to climb anything more than a slight incline
