Hello builders, size I having problems with my mount.I decided to construct a specific one.the problems I get is because my motor have 25 mm diameter for the screw and normally the mount is for 30mm, and I just can use 2 screws in the motor, and because of that, the motor constantly slide between the mount, and the belt get loose.So I design one with the screw hole that have a inclination, for make sure the motor will not slide. See and tell me what you think. It’s not finished, but the idea is this
The thikness of the mount is 6mm
