Hey guy what do you think about this product. I cannot realy wrap my mind around it. Seems wanky, maybe for super slow builds? https://www.stormesk8.com/collections/shop/products/stormesk8-damping-truck-base
Wouldnât this throw your baseplate angle off everytime you hit a bump?
Iâm thinking they could cause some stability issues at higher speeds!
this is what i am thinking too, way to wanky but still funny idea.
Looks like it would be pretty difficult to get a nut on your bolts.
What nut do you mean? Baseplate is threaded
that looks like it was designed and build without a âskaterâ in sight
Springs make things softer rightâŚyea lets put springs on it. Weâll make millions!
And not one person said âbut if it really worked it would have been on skateboards for years ⌠someone MUST have tried that before and failedâ
âWe will be the first!!!â -Said at many failed product meetings-
I feel like so many companies would save a ton of money if they got on to forums like this and just asked us what we would want. I know a few of them are out there and guess whatâŚthey are some of the more trusted brands out there, providing quality parts too!
Yeah right now the only one i know that works is Avenue Trucks.
Didnât look carefully enough to see the threads, but Iâm not sure I want my trucks attached to my board by only aluminium threads.
someone try these.
i predict instant speed wobbles.
Didnât MTBâs go away from spring trucks because of wobbles? This seems like a move backwards to me.
It looks like the bolt in the middle of the baseplate (not the main pivot) is to limit the travel upwards that would have increased the truck angle (and meant it would just flop up without), so at least there is a maximum angle (guessing 45-50 degrees, didnât really read to see if they specified).
There is a channel for that same bolt so the trucks can compress downwards for the suspension, this would decrease the angle of the trucks, and increase stability. This means theoretically while carving, the harder you carve, the less your board will turn, progressively, not taking into account the standard lean/bushing compression thatâs always present regardless of design.
This all could actually mean the opposite of your comment, the harder you wobble the more your board will resist turning even more by decreasing the angle of the baseplate⌠But in practice? Going to have to see how the interplay in resonance of wobbles to weight to varying truck angles works out on the street.
Interesting concept. It might be nice, but if the spring has significant give under load and if travel distance is at all significant (which would help for suspension purposes), I imagine these would kill the feeling of carving, to include the progressive lean/turning radius we are used to with positively raked (like Randals, or even neutral rake- ie caliber) trucks.
i must say, if they want to compete with Avenue they have to lower their price for these baseplates.
I predict launching you off like a pogo stick
I donât have an issue with the baseplate angle changing, thats not really so bad IMO. Thereâs still plenty of applications which can design around it. I donât think it will be unstable, just inconsistent.
Changing your baseplate angle isnât going to throw you in and out of turns, and it wonât really do anything if youâre holding a straight line.
Donât forget, Avenue trucks also have their angles change to provide travel.
problem about this Suspension is you only have a spring and no damper.
