Came across a standalone VESC project which is able to handle 600V and 600A for bigger vehicles. It is based of the VESC and uses the VESC-tool to program it. Benjamin has also helped a bit on it. I WANT TO SEE A DIYELECTRIC CAR IN 2018!
Tesla’s battery packs cost somewhere in the neighborhood of $8k. and that’s with mass production and huge bulk discounts from panasonic. It would cost like $20k and many hours to do that yourself, but if anyone is up for that I say go for it, I’m sure it would be a cool thing to see
Except… it wouldn’t. If you’re buying that many cells, and you wire them all yourself it wouldn’t be too bad, certainly not 8K because you don’t have to buy high discharge cells with that many rows in parallel. If you have access to a welder, then it would be cheap to build the frame. DIY cars are sick AF, the hardest part is restraining yourself to make it road legal.
Teslas battery pack has ~8000 cells. Good luck getting all the cells for less than $1 a cell. Even in bulk you’d still pay $4 a cell. Then you’re left with having to make the pack, and fireproof it with all the safety stuff their pack has to prevent runaways and damage to the entire pack if one cell goes bad.
I was using the 100 kWh pack for my estimates, but even taking 60 kWh, the smallest size, at roughly 5000 cells, I don’t see any way you’re getting those for less than 8k
I just purchased a Tesla battery made for Mercedes, it costed 7000 dollars, plus a Curtis AC-51 motor runing 144V I spent almost 18k so far. I should be getting 81 CVs. I just realized there a high power VESC for it, o wonder where could I get it from?
