So, I just got into electric longboards. Being a person with a tight budget, I decided to build my own. Luckily, I also had several longboards parts.
Rayne Amazon longboard deck
Orangatang Kegels wheels
Paris 180 trucks
So I have all of those parts, however, I still need everything that makes this little monster run. I have purchased following:
15t motor pulley
36t wheel pulley, 9mm wide
10mm wide belt
I just realised this might not work out. If interested, my weight is 65kg and there are literally no hills where I live. Do you think this will work? I’m slighty nervous about the 9mm wide belt, since it’s a one-motor longboard.
I would recommend getting a 30c battery and a 245kv ish motor, because you have no hills and it will allow some more speed. You will need a motor mount, esc, and wireless transmitter. To complete the build. Also how will you mount the pulleys? I will post some pictures of mine later if you want
@AutoHax0r I don’t think that the 10mm belt will last very long on a 9mm wide pulley, the edge of the metal will dig into the belt and ruin it. Luckily, it’s an easy $15 fix; just get a 9mm belt. It’s good practice to have a spare belt on hand anyhow (I keep one in my pack just in case, although I’ve never actually broken one!)
I semi-agree with @Michaelinvegas, but I have used these batteries in a couple of boards without an issue. I think as long you don’t push it too hard you would be fine. If you plan on full throttle runs you’d definitely be better with a higher discharge.
