Hey guys ! I’m trying to dive into this crazy and fascinating world of ESK8 DIY. I have been reading a lot, I wanted to go in a path of experimenting.
To do that, I had intentions of purchasing ESC and motor/s and a TX/RX remote to control stuff. My question is , can I use for the sake of R&D an external power supply connected to the AC power in order to provide a 36v to the ESC/motors without using a battery or instead of a battery?
What kind of power supply do I need ? I want it to be adjustable (Voltage / Amps) if possible. Also, I didn’t see much power supplies that provide more than 5A with say 40V , will this be enough current to provide to the ESC/motors circuits to do anything ? I see that most motors / ESCs are running in much higher AMPs. Any recommendations for correct power supply to convert regular outlet AC power to a ESK8 typical circuit needs will be appreciated
Thanks!
