your right, it is 2 part or something like that. i have never seen a spray can bed liner thats anywhere near as durable as the professional stuff
I got a Torqueboard 4.12 VESC with a fucked USB port and an orginal METR/HM-10ā¦does the BAUD rate need to be set to 9600 to work with the module and if it happens to be set to 12500 am I screwed?
Also have a Chaka 4.12 VESC, can I update and run detection for the TB over CAN bus through the Chaka?
I tried re soldering the pins of a new port to the resistors and 5V/ground from the receiver pins but its still unresponsive to the computer
and maybe letĀ“s look at the fusing current and not the continues current as that might be more interesting (wires less than 20cm etc). https://www.powerstream.com/wire-fusing-currents.htm
with the 12AWG we are here at 235A
Besides all of that, I doubt that somebody will ever hit the wire limit on a regular esk8.
AAAnd besides thatā¦ come on guysā¦ all that numbers are only marketing bla blaā¦ like the C-Rating on Lipos.
There is no standard for measuring all that. Some use the data sheet values of there components, some use there test results, who knowsā¦ the cheap hw 4.12 vescs are promoted as 50A continues on not only on website. You think that is possible without any additional heat sink or cooling? I doubt that.
im making a battery pack, was going to use 12/18 AWG, for the bpack and BMS youre saying I should use 24AWG?
he is reffering to the balance wires only and 24AWG is the minimum, means he wouldnĀ“t suggest to go lower in diameter than that. The main leads should be 12 or better 10AWG depending on the size of your battery.
Is 18 good for non main leads? My first pack learning all of this. I was planning on using 12 and 18. Should I do 10 instead Of 12?
Whatās your maximum discharge current? 12AWG is only good for 80, and thatās right on the edge. Personally I wouldnāt use 12 for anything above 70 or so.
18 is fine for balance leads, if possibly a little overkill. Iād go with 20 or 22, but either works.
Im using 14awg on the focboxes and pushing 80Aā¦ Havent been an issue for over a year. From focbox to battery i use 12awg.
I would go
10-12 AWG for the main power leads.
18AWG for the wires to the charge port
20-22 AWG for balance wires.
Please also have a look in our battery build threads. There are a lot of other usefull information to build a good and save pack.
Does anyone have any opinions or personal experience with these budget mountainboard wheels on ebay?
Iām looking for a middle of the road choice in wheels. Iām not interested in the highest of high end or slick looks - just something āgood enoughā that wonāt break on me
they look like the cheap aliexpress wheels. the tire has a hard compound which last pretty long compaired to others from mbs or trampa. canĀ“t say anything about the hubs, but check the bearing size. might be 10mm instead of 12mm and i remember somewhere i read it sucks to get them out and new ones in.
Does surfrodz RKP hanger position allows 2 ride heights because of the offset?
By offset do you mean rake?
I have used those wheels for a long time now. They are very slightly out of balance, but not noticeable when riding. The hubs are good with a 2 part rim bolted together. One side has the pulley built in, its part of the rim. Replacement tires are standard 200x50mm
Most mtbs i have seen pull way more continuous current than a unity can handle when offroading. It would be a negligible price difference to just add the correct wires. I think they used those wires knowing the device couldnāt output that much current. I mean, they used a single xt60 for powerā¦
I havenāt seen one yet . I would be glad to see those data, so if you have some metr data or similar I would be happy if you could upload some, including pictures of the board that I can copy it
Small edit to the xt60. Might want to watch that video with a load test.
Iām more a fan of xt90 and 8-10awg but 10s with 180a over an xt60 with 12awg without any damage is pretty lot i think. Not sure who could run such battery currents. Ok, to be fair maybe duffmann
Edit edit: might want to watch that as well.
As you might see out of the log data there is not really a constant load. If you would drive up a steep hill off-road for 500m or more that might look different.
Are M5 countersunk bolt heads the same dimension across the board? Iām having a hard time nailing down the diameter, height, and angle of the head for a project Iām working on.
That first video is great! So a xt60 can handle 100a loads for at least 15 secondsā¦
Too bad he doesnt make videos anymore I want to see a MR-60 test
im sure it exists but I like specific formats
Iso metric is the standard youāre looking for
Only dimension that changes in m5 is the length
Guys I have come here as a long time informer first time asker of the noob questions. However it may not be a noob question. Currently using a psychotiller 405 enclosure with thread inserts I want to take it off as it has been heavily modified and I have a brand new altar wedge that I want to put on the board and had tiller make it 1/8 of an inch taller just to give everything a little extra room. My question is how would I go about putting this new enclosure on using my preexisting holes with inserts in so everything lines up properly?
