What I mean is that saving the electronics can often safe your ass. The bms between the batteries can help against overdischarge which is a big cause of catching fire or random shutdowns of the powersupply or vesc. I think that the extra safety can help you
Also. I tend to agree with @b264 in pretty much all of his posts. Yes while some of us run 13s⌠And 12s etc etc. I only ventured here after building almost 20 boards, and having a really good understanding of how the marvelous pieces of things purchased on the internet can behave with one another. Thatâs coming from a guy whoâs built electronic his whole life, and worked in the power industry designing data center power control logic for years.
Itâs best to start off small, in regards to voltage, and upgrade, or build your way up. Not only for the understanding of the electronics,but for the understanding of your body on top these magic carpets. Going to fast to soon can be catastrophic. Even more so when you donât understand what is happening on your board.
If it is your first board, I really suggest anyone stick to 10s or lower and grow your hobby into a fruitful experience all around⌠The skate. The build. The protective gear. Etc.
Some of us use these the exact same way you use a car. Calling this a hobby is counterproductive to all of us.
Thatâs like calling driving cars a hobby because a few people build muscle cars in their garage. If itâs perceived as a hobby by laymen, itâs much easier to ban and regulate because itâs perceived as âoptionalâ. For me, itâs not optional. I need this to get groceries, go to work, and to live my life to its fullest. When you call it a hobby, it helps to alter public perception which hurts me in tiny ways. Each time itâs called a hobby it helps to shift the perception into âthis is something we can ban if they piss us offâ. Whereas, for example, cars â you think if it was a hobby it wouldnât be banned? Car accidents are deadly and if that was a hobby the general public would ban it immediately because itâs too dangerous to have these steel death machines flying around all over the place. So letâs do ourselves a favor and just try to avoid using the word hobby. For some, it may be, but for others, itâs definitely not â and for laymen that donât know the difference, the word âhobbyâ means âwe can outlaw thisâ.
If you chose to build instead of ride. The time you spend staring at it and thinking how you will put it together. Thatâs the piece I consider a âhobbyâ unless of course you plan to monetize your âbuilding hobbyâ.
Yes the riding may not be a hobby, it is a form of transportation. But choosing build non monetary for yourself⌠Hobby.
But what else do you call building âthingsâ (insert whatever your building and invested money in tools for yourself here). I guess you could call it a short term project, but projects come and go, they start and end, and likely you wonât revisit it once it is finished.
Hobby: an activity done regularly in oneâs leisure time for pleasure.
When you build, what drives you? The pleasing end result? If you werenât pleased, why do it in the first place?
Different strokes for different folks. Completely understand the NEED. But if you NEED something and dont enjoy building(the hobby)âŚthatâs what @longhairedboy and @psychotiller@barajabali and the rest of our wonderful commissioned builders doâŚ
PS how many kit cars do you see on the roadâŚsomeone with a hobby that built thier own carâŚnot many⌠But those builders still exist. Just like usâŚwho all chose to build instead of buyâŚ
Here is a picture of my electronics, Unfortuately, I too have very little expirence with vescâs but if you need me to, I can upload a screenshot of my bldc software and input values.
I bought some trucks with some shocks in them, the axels are 10mm and wouldnât fit my MBS 100mm All Terrian wheels. So Iâll be going pneumatic wheel route but which one will fit ?
Looks almost good. Uncheck the âlimit ermpâ and set 60.000 as max erpm and -60.000 as min.
You could set the Battery cutoff end to 34V, that gives the Vesc a bit more room before it shuts down.
Charge your batteries, and ride a round till the vesc slows down and report back how much km you went and at what voltage each cell is.
Wouldnât he need to adjust his voltage because he has basically a 10s1p so the voltage should be 37 and cut off start at 32 and end at 30. But I will agree that the erpmâs are too high.
I will give it a test after work today but I also have a question, if I set the cutoff to 34 volts, does that mean I have 3 volts of usage, before the board starts to shut down? Why not just set the number lower so that I can use the board for longer?
