I’ve been riding an ownboard mini KT for about a year and not ready to build my own yet but wanna get something I can upgrade to increase top speed at the expense of some torque. I’m thinking the M1 then swap to 100mm boas. If they’re too big I might resin print a custom wheel pulley with less teeth.
yo, im making ez cheap board and i have problem, my bateries are being discharged by only one cell, (i have two 11,1V 3S 2700mah bateries, and after traveling like 300meters i hear that battery is low, when i checked it at home two cells were aroud 3,6V and last one was basicly dead (below 3V) how to fix?
I managed to charge it but idk how it will work,
Thing is that mainly one cell from 3 total is discharging so even if two other are 3,5V or smt it will not be usable cuz of that one which is discharging so fast, also one important question, if im gonna plug in 36V baterry will it damage 24V ESC or 24V motor?
Hola, me gustaria saber, si compro cualquier skate y trae ciertas baterias de x mh o capacidad Puedo ponerle otras baterias mas grandes o de mas capacidad para tener mas autonomia??
Gracias por adelantado.
No tengo ni idea de electronica ni nada de eso. Pero si soy un manitas y cualquier cosa que vea puedo replicarla facilmente.
I Build an electric skateboard with dual hub motors. Everything was working fine for a few days untill I started noticing vibrations that gotten worse in de spend of the day when I kept riding it home. Now the vibrations are really bad and some times the wheel cannot keep up to the other because of the vibrations.
Even when disconnecting the phase wires and just pushing the board or riding it with one wheel the motor keeps vibrating at random times. At verry high speeds it sometimes stops vibrating. Also when im not standing on the board and just let the motor spin freely to motors seems to work perfect with no vibrations at all…
I opened the motor up, bell seems alright and all magnets are tight and on the right place. Also checked the wires inside the motor and everything seems to be ok. I really dont understand why it’s vibrating this badly… Hopefully someone can help me, it would be really appreciated. I was having a lot of fun riding it but it didnt even last 3 days !
