I take it you must have looked at the original thread and realized that my question was rhetorical?
Yeah. I thought you were also confused, but then realized you were just frustrated and jabbing at the other guy.
has anyone tried this drivetrain?
Iād love to know the Kv of that motor. The rim looks like the perfect size for funwheels. That should fit these tires:
@Fungineers would know how to identify a hub like the old phubs.
You probably can find it on peipei Phub500?
Side tracked but they also got this now US $359.00 | Refit kart,sled,ATV accessories,rear axle PCS-45
More economical and smaller US $35.00 | Snow Blower Rubber Track Snow Sweeper Kids Go Kart Karting UTV Buggy Quad ATV Snow Sand Snowmobile Caterpillar Tracks I could see these on an esk8
Nvm Muhammad that was easy US $159.00 | 15inch 15 inch widen tire 15x6.00-6 tyre BLDC brushless non-gear hub wheel motor for scooter phub-181
Isnāt there the problem where this will not have bead locking and would only be rim locking, and the valve stem hole.
Well, because itās more than obvious that perspective makes a difference regarding this issue, so I suspect that he knows that too, but was just trying to be argumentative (although I could be wrong). So I attempted to form my questions in such a way as to trap him.
I am interested in my first construction of an Elongboard. some research I chose to set up.
Board - 41āā Pulleys - 15/36t belt 15mm Wheels 90mm
Motor - single Flipsky R 6374 190KV 3250W
Flipsky R 6374 190KV 3250W Brushless Sensored Motor Shaft 8mm for Electricā¦
Only US$78.99, buy best flipsky r 6374 190kv 3250w brushless sensored motor shaft 8mm for electric skateboard rc car sale online store at wholesale price.
FSVESC V4.12 50a
R$288.26 45% de desconto|Fsesc 4.12 50a esc baseado no controlador deā¦
Compre FƔcil, Viva Melhor! Aliexpress.com
Anti-Spark swit Maytech mts1810as interruptor anti-faĆsca 12s 180a
R$138.32 39% de desconto|Maytech mts1810as interruptor anti faĆsca 12s 180aā¦
Did I make a good choice ?? It will work?
Battery-
IDONT NO kkkkkk What do you suggest? pack 12s6p from asia, itās absurd 521U $ on Alibaba in Brazil this is a PS4 kkk Absurd kkk ā¦
I still think I can buy 30q cells from Asia and mount them here, how much would be a good value to run 15 - 20 Km 17km / h -33km / h
Better to use Lipo?
if you can get the 6S tattu lipos those are good.
I would get a battle hardened flipsky
Hei thanks man No more than lipo 6s? I want to use it safely, not destroying the electrical part
A loopkey is a lot cheaper than an antispark and super reliable (as long as you plug it in all the way)
I will remember that in the next construction. I want to be very careful with the electrical part, I bought the antispark for that. 6s Tattu is one thoused fuckin BR $. itās heavy, with that value a little more I build a pack of 12s6p 30q
So I wanted to use self made 12s3p samsung 40t with this BMS: https://www.lithiumbatterypcb.com/product/12s-13s-14s-15s-36v-48v-58-8v-smart-bluetooth-bms-with-20a-to-60a-constant-discharge-current-with-uart-and-rs485-double-communication/ (12s 30A), in boundmotorās carbon fibre deck: https://boundmotor.com/product/carbon-fiber-skateboard-deck/ , on website they say that you can fit only 12s2p pack of 21700 cells but iām quite sure that I can fit 12s3p too. Can someone doublecheck if thatās possible because this is gonna be my first battery pack and Iām a little concerned?
Hey Iām really new to building my own eboard. Just wondering is there any coding or any hidden thing that needs to happen to make a focbox work? Sorry for the noob question.
Yes, you need to program the software using variESC Tool or VESC Tool or Ackmaniac Tool.
Ok thank you.
Hi. I got a Torque Boards motor with a 5.5mm female bullet connector. I also got a focbox with a 3.5 mm female connector. How do I connect the two? (I donāt think male-to-male bullet connectors even existā¦)
Got a soldering iron?
& Yes, there are adapters, 5.5 to 3.5mm but they are custom made. And you still need a soldering iron to make them.
