Okay here is the rundown.
Building a board from scratch after trying to learn as much as possible about how it works etc.
What I have gathered is that, in terms of battery, most people opt for around 10s2p or better in order to get a solid range as well and a good voltage for a decent top speed. I however, am poor, and this means that my options of good Li-ions are already off the table, tried looking into building my own battery but I feel this is beyond my talent so I wanted to know firstly if the setup I plan on using will work and secondly if it will give an average performance (not looking for high end as this is just coursework).
Avoid batteries from sites like bangood. Try and get them from hobbyking and look for the turnigy 5000mah packs. They come in several cell counts and are tried and tested to work fine in esk8.
As for the esc, those things are sketchy at best. Just spend a little extra and buy a cheap flipsky vesc.
If you cant afford the vesc, buy the hobbywing skate esc for hub motors. Its the best super cheap esc out there atm and works very well.
Alot of companies use it now, it will look exactly like that. Sometimes it doesnt have the black resin and is a bare pcb but if it look the same, it likely is
C rating is the maximum discharge current of the battery, measured in a weird way - you have to multiply the capacity of the pack (4500mAh or 4.5Ah in the case of the lipo you linked to), times the C number. So 45 times 4.5Ah gives 202.5A. (Take these ratings with a big grain of salt. They are usually way inflated and you don’t want to run your batteries anywhere near that number - I’d say divide by three or four to get something reasonable - 50A sounds plausible.)
If you go here and plug in all your proposed parts, you’ll get a pretty good estimate of your speed, range, etc.
45c 4500mAh (4.5Ah) which means 45*4.5 = 202.5 Amp. Battery pack should have this number and above of that. But cells should be genuined.
About the Esc, you could find some good deal with used VESC, learn about it to test before buying . Minimum is Hobbywing ESC if you can find it somewhere.
That ESC is for dual motor and not going to be as configurable as a VESC (can get a VESC 4.x for just under $100 typically), maybe see if anyone here has a VESC they are willing to part with if that’s still too much, but think single drive is the way to go. In terms of voltage if you are in the min to max range stated by the ESC you’re good, min voltage is cells in series times 3.6 (would leave the .6V buffer if cells dip below 3.0V in lipo packs it damages the cells) max voltage is 4.2 times cells in series. 8S should be usable but won’t feel as punchy (I tried with 6S 12S and now ride 10S, it’s a happy medium).
