Right lets get one thing out the way, I FUCKED UP
so please don’t kill me for that
I know this is a newbie mistake.
so the problem I’ve got is that one of the motor screw is completely obliterated.
It wasn’t so bad at first so I cut a line in it thinking I could then back it out with a flat head. that failed. I think oh ok I will just try cut another line making an + in the screw and then try back it out again with the flat head
This is the part when I messed up, and after about an hour and a half of getting pissed of at it, I come and turn it into whatever you call this.
Looks like you might need to drill it out. Bummer. Cover everything with tape to keep the metal bits out. In the future, try to stick to socket cap screws, and grab a set of wera hex-plus keys!
Edit: what he said
If you’re worried about trying to cut it and metal shavings getting in the motor you can try and J-B Weld a nut on top of it.
Just make sure you let the J-B Weld cure properly
There’s a chance it works if you get it perfectly clean and rough it up a little… It just takes way longer, and if it fails your left with a mess. Making a slot takes about 1 minute.
its stuck with BLUE loctite the one that just holds it in place until it needs to be removed. I’ve heard that the heat from a heat gun can ruin the seals on my sealed motors
That’s the motor mount screw correct? Why not just cut the top of that screw off completely unscrew the other 3 and just remove the stud with a pair of vice grips or needle nose pliers???
Some on esk8fr put paper just before the tool and … it work (a white piece of paper, simply) ^^
Maybe for the motor pulley, for the mount … dam Fiori solution looks like the only one if you don’t want to drill/cut them off.
