can i us any 63v 680uf capacitor with 5mm spacing. if so do i have to change out all of the capactitors
Yeah you can use any and just replace the bad cap. PM your info and I will send one out today.
alright and thanks man
@chaka Probably tired of hearing this but I placed an order 2 weeks ago and havenāt gotten shipping info yet.
Order #UOYS-954076
Thanks
Hey Luke, I posted this in another thread today. We should have everyone who has been waiting out by Friday. Checked your order number and you are 3rd in line as of this evening!
I got my vesc today!!! Thanks @chaka so perfect!! I set my vesc with 12v lead acid battery. No im running on bldc tool mode no problem. But i wanna try FOC mode. Should i configure FOC ( read the parameters) with the 12v lead acid battery or with my 12s3p pack from torqueboards?
I would say no. FOC has been damaging the drv chips on some customers VESCās. If the calculations are not perfect it can cause some bad spikes in current.
But if you have money to burn and want to be on the bleeding edge you can give it a shot but know that it can burn up the drv and kill your stoke.
I donāt wanna take that risk. So i will keep running on BLDC mode and be happy with it!!!
Could you elaborate on this. Iāve been running FOC almost exclusively and have been thrilled, but I certainly donāt want to damage my VESC.
Donāt switch back to bldc then. That is usually when the trouble starts. So far emax and maytech motors are the most finicky. What motor are you running.
Definitely true! The most failures I have seen were with 12s and those motors mentioned by Chaka. And some Alien/Saite motors too. You need to know what youāre doing if going with FOC.
TB 6355 listed as 230k but we determined is probably 190k Iāve been running 6s, 9s, and 12s to see which I like best Single drive
What about really low kv hubs (Hummie / Jacob)?
How do you guys set cut off start/ cut off end on 18650 packs? Same as lipo? 3.4 start/ 3.2 end?
Are you caught up now?
Iām running and hummie is running FOC with hummies motors. Works great. You hear nothing, great torque.
What do you think about the carvons and FOC? I was thinking of buying another pair for my carvons, since I have my vescs setup for hummies motors.
As they also have below 150kv, there should be at least no problem with too high ERPM.
so 149 kv (carvon) should be fine in FOC then?
Yes, if i remember correctly, 150kv up to 12s, 190 up to 10s
Edit: these values are to stay far away from the zone where it gets dangerous for your vesc or for cheaper vescs than the ollin ones
Details are somewhere buried around there:
