JKUK
January 14, 2019, 7:06pm
#1
Hello
I’m in need of a replacement battery monitor and also on off switch.
Looking at the below if anyone can recommend either for the on off switch? Also if I want to extend the cable to it, which grade of cable do I need?
Or
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F283256512583
Also any recommendations for battery monitor boxes?
Thanks
If your battery’s BMS has an e-switch built in, you can use those switches, but otherwise you’ll need to buy what’s called an anti-spark switch (easy to find with a forum search).
These battery indicators are pretty common… I like them:
https://www.amazon.com/utipower-Multifunctional-Capacity-Lead-Acid-Motorcycle/dp/B072LCD7TD/r
JKUK
January 14, 2019, 9:02pm
#3
Yea mines got one built in, just need to replace it.
What cable would I need in order to extend it?
Ah cool I’ll order one, cheers
The e-switch won’t need much… they’re usually somewhere around 22 gauge or so, if I were to guess.
What style of switch you prefer is up to you
