I planning on building a one wheel (name change to protect the innocent ) after watching Louis Rossmann discuss Future Motion failure of right to repair and patent troll. (trotter, float wheel etc)
I living in Vietnam so my only option is DIY purchasing parts from Aliexpress and Shopee and Lazada online retailers.
Below will be purchased from Aliexpress
Hubmotor: phub141 (axle 225mm 14mmx10mm flat) or phub188 (axle 200mm 14x10 threaded flat) not sure which axle mounting option is best. 60V 800W (bigger is better) not sure about this either as most build i see use 48V 800W
$139 + $52 delivery
75100 FOC Single Drive 75V 100A motor controller based on VESC has 2 UARTS, 1 for balance sensor and ADC for foot sensor. 2 for bluetooth Vesc tool App. (dont want to be limited with 60V with Vesc 6 type)
$91
60V 3Ah 16S1P 18650 battery pack HG2 3000mAh for electric scooter or unicycle. these are slim 8x2row with BMS. i plan to use 2 packs and maybe 3 if it fit.I dont have equipment to build my own pack and the price is ok
$73 2x$38
Below purchase from shopee
2040 V-stot Rail 700mmx2 will be similar to Redstar Build Redstar | DIY onewheel - #227 by KevonLaity - DIY Builds - esk8.news forums
$9
8-85V TO 1-30V Adjustable Output: Default 12V 3A: used to power head and tail lights.
$9
Battery Capacity Monitor Indicator LCD Display with Flashing Alarm 12-84V
$9
Any advice or recommendations would be appreciated, still in the R&D stage. I chosen best parts for the price as i want to keep cost low but still have a decent one wheel
I experienced in electronics and have a 3D printer
My main concern is the choice of motor, will 60V be too fast or less torque?
best way to mount the axle, I plan to use 40mm length of 12x6 aluminum bar with axle cut out inside of 20 40 rail.
