Hey Guys,
The past couple of days i’ve been working on a motor mount. The motor mount features adjustable belt tension, 50mm/63mm Motor compatibility, Various truck clamp rings and others.
The main mount is done. I am now working on the clamp rings so you can add them to different trucks.
The only problem about this mount, is that it is pretty complicated design to get cut, 3d printed is easier but not always the best option.
Here are some images
Development Process
Motor Mount
Side View
Back View
Exploded Diagram
Cool Angles
At the moment the mount is out for the public. I am going to make a few more truck rings for different trucks. I would like some feedback on maybe how to improve it and what trucks you guys would like.
Once i have it to a standard that I’m happy with i will release it for free.
Also the bolts used are:
2 M6 X 20 Knurled Cup Set Screw 1 M5 X 20 Bolt 4-8 M4 X 12 Bolt 4 M3 x 10 Bolt.
This project was inspired by @JLabs open source motor mount design. http://www.thingiverse.com/thing:1726523
