Hi. A few weeks ago I have bought a new motors to upgrade a dual drive build.
One of the motor shorted both of my VESC on a test hall sensored detection in FOC. Because one of the mounting bolt touching the motor coil.
It causes both of my VESC heated up rapidly on DRV8302.
Now I have replaced both of the DRV8302. (It was a tricky for first time)
But the problem is still persisting, powered on connected USB; DRV8302 started to heat up and get fault code on one of the VESC is OVER VOLTAGE
other VESC, is older version will not show fault codes.
What could it be?
Thank you
Check the Mosfet, They are most likely to blow before the DRV… And check all the resistor around the DRV and the mosfet specially R48 to R51…
Thank you Johny. I was wondering where can i find these mosfets to replace?
I forgot what type of MOSFET the FOCBOX uses but it should say right on the top of it. Once you have the the name of it just look it up on either Mouser, Digikey, Arrow or whatever trusted seller you normally use. Personally I love Arrow way cheaper than mouser or Digi and free shipping.
Mosfets are good. I did replace them.
it still giving me a fault code.
Fault_code_over_voltage
The highlight in red marker is where the hot areas beside DRV8302
Blue marker are the ones I have replaced.
These mosfet need to be solder dead center or they might short.
Also, Make sure that you have 5V on the 5V leg (C33) if not the Drv is badly solder and the TVS diode is most likely to be blown.
@JohnnyMeduse Are you talking about these 2? C33 and D5.
If I am not wrong these two are the diode. and they supposed to be oneway check valve.
When I checked with multimeter, I get a both beep reading on both A+ and C-. So these 2 are shorted most likely?
This one is reading out normal
Can anyone direct me please. What are these part number for D5 and C33 on Mouser.
D5 is TVS diode 5v and C33 is 100u.
Thank you
