So i have an ownboard esc and my power button got lost from the enclosure through vibrations. Seems like there are three wires… i have another power button but it has four wires… can this work somehow or do i need to find a three pin power button
Can work, the esc has 3 wires correct? One should be gnd, one vcc(pos) and one the switch point. I can’t guarantee but my guess would be that the ground and positive go to the + & - of the switch so that it lights up. Now the 3rd wire for the switching on part goes to either of the left over pins, and the last pin that’s still there should go to either ground or positive.
If you can read the switch or check the polarity of the wires that would be great so you know which wire to connect, the pos or neg. someone like @Kug3lis or another ee can probs tell you if it’s pos or neg. my guess is pos but I’m not 100% sure and wouldn’t like to be responsible for cooking someone else’s stuff
The way it works is when you switch it on the positive (just example could also be ground) goes to the esc and basically tells it the switch is being pressed and to turn on. The 4 pin switch’s are exactly the same just you have one wire going there twice pretty much.
It’s probably switch input, ground and LED+
Yeah that’s what I thought but is the switch input going to be the gnd or pos?
it can be ground too Our button shorts to ground and LED is plus
Ahh so it can be either pos or neg that gets sent to esc switch output pin. If he was to connect the wrong one would it fry?
Don’t know depends on circuit
Lol, hehe now he has to play Russian roulette
