Sn4Pz
October 21, 2018, 2:51am
#1
Hey everyone
Im wondering if anyone has a table/refrence for the sensor wire layout on the ownboard ESC, Ive got to solder the connections between the esc and hub motors…
they dont reach as is
edit: im using koolwheel hub motors as I got them on the low and I hope they work for now
@ownboard
order these
https://www.skullboardvip.com/collections/accessories/products/skullboard-easy-connector
or
Left wires are from TD motors, right is from sensor cable/connector like this: https://www.ebay.com/p/20-Sets-JST-Ph-2-0mm-6-Pin-Male-female-Connector-Plug-With-Wires-Cables-300mm/1972940603 Max amps to put on VESC should be 40A, even lower if...
and
do you have the 90mm or the 97mm koowheels hubs?
Lumaci
November 2, 2018, 9:34pm
#8
Did you ever get it? If not i have the layout.
Lumaci
November 3, 2018, 12:09am
#10
Red V+, White Temp, Yellow H1, Blue H2, Green H3, Black GND- Motor side
Red V+, Blue H1, Yellow H2, Orange H3, Black GND- ESC Side. ESC side.
If this is what your looking for.
Lumaci
November 3, 2018, 9:01am
#12
I sadly have no idea what Carvons are in terms of sensor layout.
And what i wrote is the diagram, H1 H2 H3 is the name of the sensors.
Frage
July 29, 2019, 11:39pm
#14
HI
is there somebody who can give me the diagram of this plug ?
Thanks
Fred
