Hello everyone, I am looking to built to build an electric skateboard and have narrowed it down to the two kits, I need help deciding which one to purchase. BTW I will be upgrading the ownboard kit to the 6.0 Ah 30q cell battery and upgrading the wow go kit to the 6.4 Ah panasonic cell battery. Links for both https://www.ownboard.net/collections/boards/products/ownboard-w1s-electric-skateboard?variant=12922242891818
- the link you posted to the ownboard, its already built, so technically you’re not building anything.
- the wowgo kit you linked, yes that does require building.
the performance from these will be very similar, if you do actually want to “build” a board the answer is obvious because the wowgo is the only item here that can be “built” by you.
But you might be better off buying a board that is already assembled, then if you are interested in learning about how stuff is “built” you could start tinkering with the complete board, pull it apart & rebuild etc.
