What’s involved in getting two escs to be controlled by one remote?
many issues, the four motors speed must be slightly not same, so the remote can control them well without delay and signal mess. i mean the firmware make four engines of differential speed, and conbine the two esc with one receiver, and change the protocals.
unfortunately no. I was upsold by meepo and under delivered.
What are the performance changes?
I assume quicker acceleration?
Perhaps slightly higher top speed?
Better braking?
Less range?
I don’t believe Kieran would deliberately mislead you just for a sale.
Maybe do what this guy did:
Dude way to think outside the box!!
And they are rubbish. Dont trust them. Have 2. Not using either. Throttle acts odd at times, delay in response, brakes as well. Had one totally ignore the remote and just accelerated into a curb.
I am in the process of trying to link 2 single esc to make a dual drive. Diyeboard had a 2.1 esc thst seems to just stack 2 single esc to make a dual drive. It seems like all tbey did was connect 6 wires and the power cables.
this guy did exactly this ! the only solution is to 3d print a dual controller holder which are available on thingiverse.com . this guy did the remote and also 3d printed some offroad wheels in TPU seems to work well check it out. https://www.youtube.com/watch?v=B-Gqwqf2An0
also if you do not have a 3d printer … www.shapeways.com you can upload your files and have someone print them for you.
The solution is to wire the two boards together using the 6 pin holes that are almost in the middle of the board
