Parting out skateboard, can sell as a whole
I have a skateboard i built of a basic plywood longboard deck. Running 6s 8000mah setup, 2 cells are weak and dying soon, I have not used the board much at all, but once i went below the recommended minimum and caused the two cells to die. they had higher resistance from day 1 anyway , no idea why.10%20PM(1) 10%20PM
NOTE: Looking to sell locally as shipping is expensive. I live in United Arab Emirates :slight_smile:
Currently, I have attached a front handlebar and wheel mechanism of a micro kickboard, to be safe when i drive it. I would like to sell it as a whole, but willing to part out
Parts: Turnigy Aerodrive SK3 - 6364-245KV Brushless Outrunner Motor
Turnigy Lipo Battery Voltage Tester 2-8S and Low Voltage Buzzer Alarm
IMAX B6AC V2 Professional Balance Charger/Discharger
ZIPPY Flightmax 8000mAh 3S1P 30C Lipo Pack x2
HobbyKing® ™ X-Car Beast Series ESC 1:8 Scale 150A
HobbyKing® ™ X-Car Beast series LCD Program Card
caliber 2 original trucks with bigfoot wheels and bones reds bearings
motor mount and pulley I bought from fellow enthusiasts on this forum, metal gears, and aluminum motor mounts
I have other leftovers, like extra threadlocks, heatshrinks, 10gage wire, extra belts etc
Is that enclosure paper mache?
If so, thats honestly the funniest and perhaps thre est diy part i have even seen.
naah , its a 2cent attempt on fiberglassing :slight_smile:
Its pretty tough. My build in progress has an enclosure almost identically shaped. I have spent probably 18hrs getting to to a super glossy perfect finish. Most people have no clue how hard it is to work with without a mold.
yeah i remember, placing tape over a food container for a mold, then placing it on the board to get the curve.
Next time, try and find something like a food storage container where the inside dimensions are nice. Then take the top and trace it on carboard and cut it out. Glue the cardboard on like the brim of a hat and that will be the skirt your enclosure is mounted by. Then fiberglass small strips of mat glass in over about 2 days.
The results are alot better and easier to finish. I just wish my most recent enclosure would have worked like that. I could find a container i liked.
Just make sure to add mold release. I cheap way to make some is to melt candle wax and grease of some sort together and then its soft and easy to rub a very thin film onto your mold.
Alternatively, mold one out of clay if you are confident in your abilites. Clay makes great molds.
thanks for the info, will help me in the future but definitely not for e-boards, or in the next life, im broke , need a car for work :slight_smile:
