I am working silently on a really stupid thing, which involves me putting the vesc right next to the battery in a box in the middle of the board. Then I just route the phase wires to the motor mount, which is going to be around 400-500 mm of travel (15-20 inches).
I thought this should be relatively problem free, since i only knew about the battery wire length issue where induced voltage spikes fry the vesc. But then I read a post by @Deckoz which has me a bit worried, he mentioned a phenomenon I have not known about, where the back emf reading can get distorted over long phase wires and the motor can simply stall during riding. Scary.
Does anyone know a limit where this can start happening? I read that @GrecoMan has been running really long phase wires without issues, but I have no idea on what hardware.
You should be relatively fine me thinks, just make sure to use large enough phase wires, probably 12-10awg to minimise resistance.
Is this going to be on a mountain board? Or just a standard longboard with the gear in the middle? @Sirshaunsta might be able to help as I think he had his batteries and vescs in the middle of his board
Its my understanding and I’m sure I will be corrected by far more knowledgeable people than me if I’m wrong but phase wires cause desync when they are different lengths. Dual motor set ups with one side shorter than the other will experience problems and the three wires on a single set up need to be the same length. As for length, as @pat.speed said compensate the resistance with a bigger gauge wire and you should be ok.
I have never ever seen proof of 10-12awg phase or battery wires that are <1m lenght cause anything at all except for current to flow.
If they are proper copper, the resistance is negligible so I would be ultra surprised if different lengths of phase wires would give any problems. Electrons don’t “take time to reach the other end” …
Yeah I’m not sure your quite right there, as the vescs are separate hardwares meaning they do not care about each other’s motors postition, except for traction control.
As for different lengths of leads on the same motor, I know that small variances (1/2” or so) do not make a difference.
Yeah I’m not entirely sure either but all I’m going on is a twin motor set up on an Rc I built. Problems with my esc’s until i paired the wiring. As for separate, are they? They are both controlled by one receiver and if one motor has more resistance than the other then surely they will be out of sync. ( I’m learning here please correct me)
your motors are synced by being both fixed to the same board and the wheels running on the same ground. You can use different motors, different cables etc. They might not always push with the same torque but if theres no huge difference, you will not notice. Mono drives work too.
Never heard of this DESYNC but it would make sense as even with car stereos if you run a thin wire over a long distance the power and signal get weaker.
I have 16 yes 1 and then a 6 (16) 5s 5ah lipos between my legs with between 12 and 18 inches going from battery to vesc to motor in all four corners. In testing I’ve found NO ISSUES at 10awg but I’m also using thicker cables because of my battery size and to utilize all power of FOUR 190kv brushless motors(sk3-6364)
What dif you end up with? Did it work? im building a trampa board myself and was wondering if it is possible to have motor cables stretched to the middle of the board.
It’s a trampa board you have right?What is the Awg for the wires you used? What about motor sensor?
A picture would be appreciated, if you have a trampa board.
Sorry for so many questions.
Its not a trampa I wish lol. I have just some lame crappy chinese longboard with sawed off ends.
I am using AWG 12 wire, could go for AWG 10 or 8, every bit helps. Especially since after going hard for a longer while like up hill, the wires get rather warm over a 10-15 cm distance from motor and the mosfets. More copper never hurts lol
Oh, and I am sensorless for now. If you use sensors, I would make sure the cable is shielded. Probably not entirely necessary, but would not hurt I think
