I’m using @chaka’s 170kv sensored motors, and Enertion VESCs, and thought I would attempt to use the hall sensors given I would like nice smooth operation at low speeds.
But is the ordering of the 3 phase wires connecting to the VESC also important? And if so, what’s the order? The Ollin motors come with phase wires colored red, yellow, and black.
+5v and GND cables (red and black) are important, but the 3 sensor wires doesn’t matter as long as you do detection and set it correct on the sensor table on BLDC tool.
gotcha, those are typically called phase wires. Just make sure they’re spinning the right way, order doesn’t matter. There will be 3 combinations that will make it spin 1 way and 3 that will make it spin the other way. As long as the hall sensor table is correct, you’ll have no problems.
