I’m about to go out with my dog to the local park and I do a quick pulse on the remote and it spins fine. I put the board on the ground and kick off and doesn’t go I thought it was just a loose connection inside so I switch it off and leave it at home. The build is this one just new motor and wheels and has been working fine since November. this is it - https://www.electric-skateboard.builders/t/esk8-build-to-get-to-school/75385 -
Here are some problems I’ve already checked this afternoon.
ok never mind I’ve figured it out, the remote is broken because i went into bldc tool and looked at the live ppm when i pressed on the trigger and no movement so i just need a replacement remote or find a way to fix this one
