I have been trying to make a DIY spot welder from car batteries and Arduinos for weeks and have had no success. As a result I’ve opted for soldering. I know the basics: don’t short, hot soldering iron and small contact time to reduce heat. However this is my first time and would appreciate any advice or help this community can give!
I’m using nickel strip and 60 year-old lead roof welding tool as it has a huge thermal mass.
Nickel is not the easiest to solder on.
Guess you would go better by using a copper wire or bar.
Where are you located?
Maybe somebody here can rent you a spot welder
Weld the solder to the cell first.
Then weld solder to the conductor. (nickel in this case)
Then weld them together.
Also, everytime you solder anything you should always try your best to pull them apart after cooling. If you can pull it apart, it was a bad weld and needs to be redone anyway. This kind-of applies to 18650s also. You want to do that, but you don’t want to accidentally short things out, either.
You should keep a piece of metal handy so that after you remove the iron you can press it on the end of the cell to suck the heat out faster and keep the heat from going as deep into the cell.
Also, protip: the positive connections are the most difficult, so it’s better to troubleshoot those ends
Also if you’re soldering, you may as well use copper and not nickel.
Sorry I don’t want to be a dick, but just my 2 cents, this soldering work is awfull.
Better bring your cells to someone with the right tools and skills, this batteries can burn down your house easily.
Nothing in soldering is referred to as welding, so keep that in mind.
It appears that you are using a pipe-soldering, soldering iron to do the work. That can work, but it takes lots of practice and skill. If I were you, I’d use the big soldering iron to tin the nickle strip, then use your other iron that I can see in the back which appears to be temperature controlled, to do the actually soldering of the nickel to the cell.
Prep your surfaces. Scuff your battery and nickle strips with sand paper to lightly turn the surface matt. Then clean the surface with isopropyl alcohol.
Put a bit of flux on each surface to be soldered and then use your temperature controlled iron with a well tinned tip at ~450c or so to quickly touch the battery surface and then add just enough solder to get a little blob to stick. The little blob of solder should be shiny when it cools, and well adhered to the surface. This will take practice.
This process of sticking a bit of solder to the surface before soldering things together is called tinning and is vital. Use the same process to tin the nickel strip at where you intended to join it to the battery.
With both surfaces tinned (battery and nickle strip), put the two tinned surfaces in contact and clamp them so that they won’t move when soldering. You can now use your still well tinned and clean soldering iron to heat the top of the nickel strip such that the tinned solder on the bottom melts, the melted solder from the nickle strip, should then melt the solder on the battery terminal and the nickle strip will sink into the top of the battery cell. When it sinks, remove the soldering iron and let it cool.
Spot welding is better, but if you must solder, do it as above for good results.
I saw you melted solder onto the top of the cell but it didn’t appear to be stuck/welded/tinned. Just physically touching. I bet if you took a straight screwdriver, you could pop it off…
But then again prying on the end of an 18650 with a screwdriver is a very bad idea in general
