It’s way easyier to do 2x 5
60-80a is always safe. standard vesc 4s are pretty happy at 40a battery amps so if you’re running dual an 80a bms is fine. thats if you want to discharge through the bms. the charge only bms can be anything as long as it’s rated to charge at your desired current
Read that namasaki thread, its gold but somewhere on here and I can not for the life of me find it is a clever bastard that has built a charger with a built in bms so you don’t need one in the enclosure. Thought I bookmarked it but alas…
Debatable but ok. I’ve done both and don’t find one easer than the other
Well you do more series connections, 5 to be exact and the is more space to mess up, and you don’t mess around with lipos.
Funnly my first build was with lipos.
Wait what?!?!? I’ve been thinking about doing this myself. Must find.
I think its in a build thread and a recent one. I will do some research and get back to you
Explain please!
Its in here but its aimed at lion cells. Still a bloody good idea and if you can combine the namasaki thread info and this then lovely stuff
I like that idea a whole lot. Thanks for the search. Any input on what c rating on a lipo pack to use. 20 to 45 is the range I see most. Thinking about getting 2 of these and maybe adding a 3rd down the road.
Most c ratings are over exagurated by a long shot. 30c will actually be like 10c. Id say min 60c.
Even 10c is 50a at 5000mah lol
I don’t use lipos in esk8 tbh but that namasaki thread has it all. From what i can gather though 40c minimum.
That’s also true. You should be fine with that pack @venom121212 Edit: especially if your putting them in parallel it should be more than enough.
Looking at doing a charge only bms if you can recommend one. Do you have any thoughts on the linked battery above?
If you watch the video you will see that he pushes the balance wires into the male ends of the jst connectors from the battery. He then hit glues them to stay in place. Just solder the damn wires!
Mabye it was for demastration purposes lol
nah, that guy was on the forum last year and had a shitty “company” for a while. The pictures on his site were literally taken from the Just Pictures thread!
Edit: morale of my story, he is and idiot
I just skipped around all over the video looking for hot glue. 20 minutes of bumbling and mumbling, don’t have the time and energy to sit though it. Couldn’t find any, but he took the bare end of the bms balance wires and stuck them into the jst of the lipo balance connector? Yow.
The reason I did five 2s instead of two 5s was to keep the battery as thin as possible for maximum ground clearance under the deck. I agree with you though, it would be less work to put two 5s together.
As for the C ratings, many of us have come to the realization that the C rating x capacity does not give a accurate max current rating. For example, my 5ah 60c Lipos are no where near capable of 300a. They start sagging at less than 50a They are good Lipos with very low internal resistance. Only about 2 miliohms per cell. Look at these charts showing voltage drop at only 23a charts where run on only one vesc in a dual setup so I double the current.
