I emailed them and asked more specificly about the gearing on thoose! We’ll see what they’ll say unless someone on the forum with one can reply quicker!
Might give them a try!
Evolves are 66 tooth(at least that’s what it says on the controller). The ones that come with the AT boards are 7’’. The only problem is you would have to cut your trucks because they work like Enertion’s pulleys.
Ah thats a bummer, kinda wanna avoid touching any of the material of my truck.
Does that mean the bearing fits into a part of the pulley that sits on the wheel instead of inside of the wheel?(Not familiar with how the enertion pulleys work)
You can - I bought the hangers from evolve and a set of gullwing sidewinders - much cheaper. Just have to change the bushings to suit - standard gullwing ones are way too soft.
Ollin motors fit perfectly
standard gullwings come in 9 and 10inch hangers - the evolve hangers are wider. This gives great stability as well.
It’s just cheaper to buy the gullwings, then the hangers from evolve because they charge a lot for their trucks, they sell them piece by piece.
Gullwing trucks are super carvey - not meant to ride at speeds greater than 30km/hr - thats why you need to ditch the standard bushings and try something a bit harder.
I actually just placed an order from my supplier in China on a 2wd off road longboard kit including 4 pneumatic wheels with pulleys, 2 trucks, 2 motor mounts, 2 motors and 2 belts. Basically everything we need! I will let you know if it is worth distributing
