I’m trying to set up a hobbyking VESC with a GT2B receiver. The motor setup was fine, but no data is coming through for the ppm setup. I have enabled live data but when I click apply it says failed applying pulse lengths. The receiver seems to be connecting to the tx because when I turn that off the signal light flashes.
The signal is on a Servo connector with the Vcc so I only have one option for channel.
I tried a servo in channel 3 and it made a noise when I moved the wheel on the tx so it must be connected, but when I put it in channel 1 or 2 it doesn’t respond to any control so I don’t think those connect to the throttle.
