I got a set of MBS Rockstar black anodized wheels and having trouble seating the bearings. I am sure the bearings are the right size. Should I try sanding out the hole a bit or is there other ideas? I do not have a bearing press so need ideas that use standard tools…
I use a small punch and run it around the outer race, tapping Softly and working slowly. Putting enough pressure on the inner race to seat a tight-fitting bearing will damage it.
Edit: if you go at it in a star pattern, you’ll have good results
It might heup to use the outer race of another bearing to exert the pressure.
I’ve used a bolt, nut, and big washers that cover the whole bearing, with a cheap throwaway bearing on each side of the thing I want to squeeze, and use a ratchet to tighten.
Not sure the punch is a good idea. It’ll probably deform the race?
The punch works if you’re gentle and patient! I like the idea of using another race too, or a sacrificial bearing. In my mind, the critical aspect is not exerting pressure on the inner race
