Programmable Bestech BMS
What about a BMS that is software configurable?
http://bestechpower.com/communicationbms/BMSD328.html
I’ve been trying to find somewhere to buy that exact BMS, saw it used on some eBike forums.
Interested too. replying to get updates if It comes to a GB
New BMS just came out to replace this. It’s definetly meant for higher powered applications though. HCX-BMS-006
(https://www.dropbox.com/s/qdq6acb2wa2ojqq/HCX-BMS-006-4S-32S-100A%20BMS%20Data%20Sheet.pdf?dl=0)
Can you direct link to the source or Dropbox link?
I got a quote on that one for 139$ a few months ago
$139 Yikes! Which one?
is it worth this? I really like idea of getting data from BMS and I thought I might be able to config it to bypass discharge.
I am wondering if it would be useful to change the overcharge set point to say 4.15 volts so that balancing would start before full charge of 4.2 volts per cell. Am I right that all other BMS don’t float until they reach 4.2v per cell? I want set my charger to 4.15 to save some space for regenerative braking but still have parallel group balancing.
