Hello, I have a space cell batter connected to a VESC and the VESC connected to the VCC channel of the radio transmitter of a FS-GT2 radio remote. The part of the remote connected to the trasmitter is on channel 1. Please let me know if that works. I know the next stage is to solder the VESC cables to the motor. Once I connect those three cables what is the next step? I was told I need to run a test using the computer but I have no idea how to do that or what that means. If someone could please give me some step by step instructions that would be helpful. What program do I use to run this test? Do i need to write my own code? etc…
Hi Arpitdave,
Check out the VESC fan’s here: http://www.electric-skateboard.builders/search?q=vesc%20faq
They will give you a better idea of how to set up your VESC.
You’ll need to: -change the settings to the Space Cell recommended settings -run a motor detection -set up a PPM input (your receiver)
All of this info can be found in the FAQ’s!
For starters, I believe the VESC is supposed to be plugged into “channel 2” on your receiver instead of one.
