I haven’t tried these in particular. The reason is simply down to stator size. I’m not entirely sure what the size of the stator is, but the stator size will tell you how much iron you have in the core and the amount of copper you can fit in the motor. There is a certain size of stator, that becomes large enough, to were the motors don’t become saturated under any case. These small motors, simply can’t fit the amount of copper or iron (stator size) to run efficiently. Once you hit 160 F, motor efficiency goes down the tube. And these small motors will always struggle to stay cool under harsh riding.
Everything comes down to how long you ride for, how many hills you hit, your weight as a rider, and how you ride.
I never said you can’t have good results with these small hub motors, but that they have a lot of weakness, that will result in a shorter life of the motor specifically (possibly, very short, but best case, a fraction of what you should get from a motor). Unless you limit amp output to these little motors to control heat, but then, you won’t get performance anywheres close to a belt drive system. The goal is be able to compete with belt drive systems, and it’s physically impossible, in that little space, to fit enough stator (iron) and copper to make the motor be able to run the way we need it to compete with belt drives. Maybe meepo hub motors work, but they are very limited in the amps you can put into them, which limits torque. In addition, with the limited amount of copper and stator, they need even more amps to get the same torque as a larger motor.
For example:
Before, I needed 4 amps to cruise at full speed on flat.
Now, I need less than 2 amps to cruise at full speed on flat. Which is going to result in better range?
Now, you can say the meepo gets great range, so don’t they have great efficiency? That’s due to is lower top speed. 15 mph is the best speed for efficiency of most of these motors. 10 mph or less, and your not running efficiently with a hub motor. I like to ride at least 25 mph at all times. Over 20 mph, the wind resistance is exponential, and kills range. So this is why it takes 4 amps for me to cruise at top speed. At 15 mph, it goes back down to around 2 amps again on the old motors. On the new motors, Its about 1 amp to cruise at 15 mph. But I never ride like that. So I get shitty range. It’s not that my small motors are less efficient than meepos, just that I like to ride faster at all times than the meepo motors can even do, so my range takes a punch to the gut.
BTW: All of these numbers are per motor. System includes 4 motors.
At the end of the day, they can work, for certain people, but if your looking for reliability, durability, power, and better top speed, you simply can’t get that from a small motor due to the limitations I’ve outlined in this thread.
Maybe for you and some others, they will work, but it’s better to not be working your motors near their absolute potential. That will lead to issues.
