Your talking about belts drives. Belt drives have resistance when spinning without a load. Add more belt drive motors, and you gain more resistance, so yes, it takes more energy.
Good hub motors have little to no resistance when spinning without power. Add more, and you split up current and you should reduce waste. I’m not 100% sure, since I haven’t done real world tests. But @FredSaberhagen has a good point.
If you ride in variable terrain like me, then theres times I need to climb mountains, and theres times I need to ride flat for miles, in the same trip. Now you’ll say a dual drive belt system can be geared to be efficient for both circumstances, I see that one coming.
Hub motors are a bit different. When climbing steep hills, due to the disadvantage I believe we all agree on now thanks to frank. 4wd gives good efficiency at all times. Why is it that I could get 20 miles with a 4wd hub motor and 8ah battery (if in the ideal conditions), and little heat, if it was not efficient?
Even if I was to get worse efficiency with 4, I get closer to the no load speed, more predictable acceleration, better handling (especially around corners), and your doing less work per motor, so you should expect a better life cycle.
Yes, it costs more up front, but if it last 5 years instead of 3, is it really that much more?
The only real downside is more weight. But for people like me, it’s not an issue. I hope on and go to class. Put it down, charge it, and when I’m ready to go home, I unplug and go. I don’t need to carry it around very much.
Even if it is less efficient, by how much? Clearly, not what your saying. I don’t think anyone can get 40 miles on an 8ah 12s battery. If for some reason, it’s not as efficient. At most, I would expect 25 miles from a good belt drive setup with this battery. That 5 mile difference is more likely a result of rider weight in this case, rather than efficiencies.
