I have bought a a pulley and belts kit from Ebay for my MBS ALL TERRAIN wheels. However when putting them on my caliber 2 trucks, the hole in the pulley stopped the wheel from going on fully, it needs to be a thicker bore. this caused it to scrape on the truck hanger. I’m in the Uk and not to sure what to buy because i don’t want them not fitting again. i have a 3d printer so maybe i could try printing them. Many thanks in advance
There should be a few 3D printable pulley for those hubs. The searchbar is your friend.
You can also grind down the hangar, or the inside of the pulley, as I’ve done.
Disclosure:I don’t have these hubs, my experience is on regular 83mm wheels
Also are we talking just bog standard Caliber II trucks or something with longer axles like TB218? If you have any extra axle space, you can use spacers or washers to help with the issue.
I was thinking about doing that. however, even the bolts dont align with the holdes on wheels. I have seen the files by Junior potato and was wondering if anyone has had any luck with them…
Ah I see.
Do you have the link to the seller?
Recently one of the eBay sellers that’s actually on the Forum got some parts mixed up and people got the wrong bolt patterns on their pullys.
He replaced them if I remember correctly
This is where I got them from, forgot to mention that even some of the boats didn’t have a hex key space, they had manafacturing faults. Three of them were faulty
