Choose the faster delivery option. It’s not as long normally as it states…
I’ve just realised the size I’m using most of is 160mm!! So anywhere from 160mm if it’s really slim to 180mm if you’ve not squeezed 'em tight enough
About 2.5euros. I think will send you a link when I get home Dont know about the delivery time tho probably about a week or so if you pay something like a dollar
found a serious deal theyv 220mm up to 320mm wide pvc heatshrink cheap …
ill let ye know what its like
I think 220mm will be too wide… Does it say what it’s shrink ratio or diameter is?
20£?
There is fitting heat shrink on ebay and aliexpress that costs below 5€ per meter
any links?
ill just use foam maybe kydex if it is
2/1 shrink ratio
150mm is too small for a 2 x 18650 wide, single layer pack… 160mm is the minimum that will fit.
You want this one…
220mm with a 2/1 shrink ratio is 11cm wide my pack 14 plus with abitta foam added… should work…already ordered the other stuff
Found a 190mm that’s rubberized for shock absorption:
pity its in the us
Yea that might be tight but I didnt order it yet so all good thanks
