Just a quick question to help understand some electrical concepts:
Say I have a 12s2p battery with 30q cells. Each cell has a max continuous output of 15 amps, according to the spec sheet. How do I calculate the voltage, max current, and max power of the whole battery? How does that change if I decided to do 12s3p instead?
12s2p max continuous current = 30 amps
max power (ignoring esc and motor limits) = 30 x 12 x 3.6 = 1296 watts nominal
or 30 x 12 x 4.2 = 1512 watts at full charge (not really real-world possible)
12s3p max continuous current = 45 amps
max power nominal = 45 x 12 x 3.6 = 1944 watts
or 45 x 12 x 4.2 = 2268 watts full-charge max
Is that correct?
Does that mean that adding additional cells in parallel (increasing p number) always increases the battery’s maximum output current?
