Question about motor sensor cables connection
Hi everyone
I’m getting a problem connecting my motors sensor cables to my ESC, my motors have 6 sensor cables and my ESC sensor connection only has 5 cables
My motors are: ELECTRIC SKATEBOARD MOTOR 6355 190KV
And this is what they say about the sensor wires af
And this is my ESC: Dual Belt Drive Outrunner Motor ESC Speed Control Kit
http://www.diyeboard.com/dual-belt-drive-outrunner-motor-esc-speed-control-kit-p-561.html
Here is a picture of my ESC sensor connections (GND, W, V, U, 5V)
And here is a picture of my motors sensor cables
I want to know what do I have to do to connect my motors, if there is someone here who could explain me what to do I would really appreciate it
Had a similar situation, only vice versa. Found this explanation, and was successful after changing the cables according to this: forum.esk8.news/t/hall-sensors-question/14050/4
In short, ignore the 5th cable of the 6-plug, and let 6th go to the 5th of the 5-plug, all others 1-to-1.
Thanks :grinning: Then I guess I only need to remove the white(temp) wire… That was easy… :sweat_smile:
9/10 the white wire is a temperature wire. If the vesc has no “temp” leg then you can omit the temp wire. Remove the white wire and slide everything over towards the red wire.
Do your research on that. It’s worked for me but it wasnt with TB motors.
My ESC has a temp feature…
As per an item description, yes. As per the vesc you pictured, no.
Diyeboard isnt a reputable source for parts. Plus their parts are a little behind times.
I you check @ forum.esk8.news in the parts for sale threads, you can find reasonably priced 4.12 4.20 vesc that will accommodate those sensor wires as is. Plus it’s a valuable upgrade.
In my case, the motor had the 5-pin-plug. Maybe it says “don’t expect a temp sensor for this price”. The same attitude might be behind your ESC’s plug.
Tengo una duda grandicima, sera que me pueden colaborar con ella. Es que en mi caso compre este motor (8360 Motor sin escobillas de rueda de cubo de monopatín con motor de rotor exterior de impulsión de pasillo Motor de rueda de cubo de scooter Motor outrunner), y el siguiente drive Controlador de patinete eléctrico con Control remoto, Panel de Control de Motor de Doble accionamiento sinusoide, juego de Control de patineta eléctrico esc. Yo compre solo una rueda pero compre un drive dual pra a futuro comprar la otra rueda. Mi pregunta es que puede el motor funcionar con ese drive sin necesidad de comprar otra llanta.
