Hi everyone.
I am running discharge through my 60amp BMS. It seems that BMS will shutoff once my voltage dropped at 36v.
My pack is 10s4p and this is the BMS I use. Is anyone have the same experience with this BMS
I have torqueboard vesc.
Is not the vesc that cutting off.
Is my BMS that cut off the power completely once it hit the 36v. because the antispark switch is cut off too.
My setup is BATTERY - BMS - Antispark - VESCs
Are you running bypass BMS or you have it discharging through BMS on your setup?
