I am interested in buying one of these two…
(1) The smaller motor 6355 has more watts 3520W+ = I want the one with more power. Also a bit confused why the smaller motor has more power.
(2) How long is the sensor wire? Does it work well with VESC6? I have had issue with some other motors hall sensors.
Why dont you send him a Private message instead of making this topic?
I thought it would be helpful for everyone + him (free advertising). I buy tons of stuff from builders/vendors here.
But do you know about the motors? They are the standard Maytech brand so this maybe more public knowledge rather than something specific to his website. Just need a quick reply… I am at the point of purchase.
Thx!
No sorry, it looks like a mistake because to me it’s like saying a 6374 motor is weaker then a 6355. But everything is possible @psychotiller
Sebike
November 11, 2017, 10:11pm
#5
According to the specs at the Maytech website the 6365 is rated at 3520 max watt and the 6355 at 3510 watt.
Ok thanks yes that’s what i saw on michobby too. So it must have been a typo.
6365 >= 6355
It’s a typo. Not mine, but they wouldn’t change the info so I left it alone as well. And, so you know the stator is longer. The 6365 are actually 6369
Thanks for the info … 69mm might hit the truck… the outer edge.
Quick follow-up are they both about the same power then? Due to that size I would be limited to 6355.
They are very close. I weigh 200lbs (210) and the 6355s are plenty powerful.
