What I’m saying is that I would put the fuse on the charge port itself, not somewhere else in the circuit like that.
BMS bypassed with loopkey and discharging with lights/accessories circuit
If your BMS doesn’t have C- or CH-, then connect that wire to P-
beautiful diagrams
Yup, I read some topics about it and I remember this opinion. Ok thanks.
In my case, something like that:
I say nothing
I bought these, they are ok?
Looks fine to me
Good! Please can you also confirm the fuses that I linked?
I didn’t see any links, but these work good for charge ports
for 5A max charging. I epoxy them inside the enclosure somewhere near the charge port and just solder wires to them. If you ever blow it, just epoxy a new one on top of it. Typically they don’t blow, and if they do, then you’ll have fun changing the fuse knowing that you’re not buying a new battery or house.
Great! Thank you. I actually think I’m going to use the fuse holder ( I really like a clean hw setup ).
What about using a fuse to avoid only a short circuit identifying the device with the lowest amps limit?
For example my VESC can handle 150A (instant peak), so using a 120A fuse might be somehow useful for the electronics? Considering that I don’t expect to set “motor max current” higher than 85-100A.
Sure.
Cheers
Very clean!
Thanks!
I shared the design if it could be useful: https://www.thingiverse.com/thing:4776368
Why is the fuse on the negative?
Because we are currently in the shadow realm
YOU NEED TO WAKE UP
Because the nature of MOSFETs means a common anode design is cheaper and more powerful, so that’s why BMSs are designed to switch the negative lines.
No, an added fuse on charge line, is shown as on the neg.
It doesn’t matter which side it’s on.
