Hello What is the included cable for? Its a 6 pin female To a different type of 6 pin male
Thanks
Thanks
Sounds like a adapter for hall sensor. Can you provide a picture?
It fits into the hall port or the program/debug port My hall sensors are open cables so i would need to know if i can simply unpin this connector or if i need it for something else than the hall bus
That is a hall sensor adapter cable for sure. You don’t need it if the hall sensor cables fit right on the VESC hall bus. Actually, I need a cable like that so if you’re putting it on a shelf somewhere, I can buy it from you.
I need the connector for my hall sensors
Im sorry
But thanks for the help
I have two of those I don’t need
Can I buy one when I deliver your wheels?
You can have it for free
