Hey as of late I’ve experienced VESC resetting when in R-spec mode only when high amp draw situations happen. I’m curious if my vesc settings have reset or anything anyone would add
6355 190kv dual setup
10s3p motor
All stock raptor 1 setup outside of 97mm abec 11 wheels.
Curious if I should make any changes to settings or if the extra draw of the 97 mm wheels is causing the VESCs to reset. Here is a screen shot. If any other info is needed let me know.
It will drop about 12 percent on the initial jump and settle at a 6 percent sag when at full speed on the bench. Seems like it’s been about like this since I got it.
I can understand it shutting off if the battery dropped to a certain extent but I can’t see it sagging from 100 to shut off rate right out of the gate on the bench.
I think I’ve read of other raptor batteries going bad. 25rs aren’t that great and 10s3p is small for a dual. I have same cells in 12s4p format and they sag a bunch. Going to upgrade that pack soon. Bluetooth module is cheap and ackmaniacs app is free
check your vesc capacitors, i had mine fail on my Raptor and i could not fully accelerate or the vesc would shut off, after i replaced the caps this thing rips again.
in my case one of the soldered leads was broken off the capacitor i was able to move the capacitor up off the pcb. in theory i could have soldered it back but i had already ordered new capacitors from Axel. Also if the capacitor looks “puffed” up its bad the metal cap on top should be completely flat if its domed or puffed its bad.
I have the same problem with my Bolt Motion. I have two speeds. At slower speed, everything is great. At faster speed, the board resets often (every 30 seconds?). Even more frequently going up a hill. Not sure what the problem is either. Any luck? Did you try the capacitor thing?
